while driving down the road my car stalled out. once i pulled over and tried to restart, i knew that my battery wasnt dead (it was cranking over) and figured my main relay (aka fuel relay) had gone bad again since it is such a common problem with the 90-93 accords. Then i checked this and found that my fuel pump was turning on when ignition is turned. I found that i had no spark from the distributor or to it (i assumed you were supposed to have a spark going into the distributor main from the ignition coil). I replaced the ignition coil and the problem continued. Where should i go from here?
Feb 18, 2007 at 6:32 PM
