90 accord: 80 amp Battery fuse keeps blowing
1990 HONDA ACCORD
MEZZYJ
battery fuse keeps blowing when i attempt to connect battery to terminals. What equipment do i need (voltmeter, bulb test) and what should i be looking for?
May 18, 2007 at 10:51 AM
AUTOPOP
  • 49 POSTS
[quote:7282e501d5="mezzyj"]battery fuse keeps blowing when i attempt to connect battery to terminals. What equipment do i need (voltmeter, bulb test) and what should i be looking for?[/quote:7282e501d5]
Make sure you are not reversing polarity of cables and check for positive cable insulation to make sure it's not grounding and creating short.
May 18, 2007 at 11:49 AM
MEZZYJ
polarity is correct, no problem with insulation.
I did have brakes, master cylinder and booster replaced by reputable dealer. The next day, the battery was dead. Jumped it and let it run, turned off engine and it started ok but 3 hrs later it was dead again. Replaced battery because i thought it wouldnt hold charge but sounds like it was being drained by a short. I connected the terminals to battery and blew the 80 amp battery fuse (correct polarity). How do I narrow down my search for the short? I do have a 12 tester with red and green light and a new 80 amp fuse.
May 18, 2007 at 12:32 PM
Hey MEZZYJ,
It looks like you have an alternator that is out, here is a guide and a wiring diagram that can help you get the problem fixed.
https://www.2carpros.com/articles/how-to-replace-an-alternator
Replace the alternator and recheck the problem.
Best, Ken
Jan 17, 2017 at 12:24 PM
