[quote:1e0921901c="KHLow2008"]Hi jyd1234,
Was anything done prior to the increase in consumption?
The fuel filter is located intank with the fuel pump and replacement is required if the fuel pressure falls below the minimum requirements.
If performance is decreased from previous, it would increase the fuel consumption and apart from the maintenance items replaced, the tires and wheel bearings should be checked.
If it is possible to get onto a diagnostic machime, you would be able to check if the O2 sensors are working correctly.[/quote:1e0921901c]
Nothing was done prior to the increase in consumption.
After we noticed the increase consumption, along with changing the air filter and spark plugs, We did change the tires. We put on brand new H rated tires.
How much do you think it would cost to inspect and get the fuel filter replaced on a 2003 Accord?
Thanks for the tip on the 02 sensor. A friend told me that if the check engine light hasn't come on yet (which it hasn't) then there is no need to check it...but some say a 02 sensor change could increase fuel consumption up to 15%. Is this true?
Oct 18, 2019 at 2:05 PM
(Merged)
