When you say move the radio around, do you mean the physical radio is loose? Is it still the factory radio?
If that is the case, have you checked under the dash near the radio for a loose ground or connections?
As far as the exterior lights, do the front parking lights work? If not, check the two fuses I highlighted in pic 1. In addition to just checking the fuses, make sure they have power. Here is a link to help with that.
Pic 2 shows the fuse location for the interior passenger side fuse box. Pic 3 shows the fuse in the under hood fuse box which sends power to the interior fuse box. Pic 4 shows the left rear of trunk where ground 601 is located.
If the fuses are good, the bulbs are good, check ground (G601) which is for the tail lights.
______________________________
May 17, 2021 at 12:06 PM
(Merged)
