Engine Mechanical problem Two Wheel Drive Automatic 76500 miles
My 2007 2.4L Honda Accord has an unpleasant vibration at idle with the car in gear and my foot on the brake. The vibration comes right through the steering wheel and is worse when the aircon compressor cycles on. Also, turning on the lights and putting a load on the alternator makes the vibration worse.
When you shift the Gear to "P" position the vibration reduced. I have replaced the all engine mount from workshop, but problem still persisted. If I gently rest my foot on the gas pedal and raise the RPM's to just under 1000 things smooth out.
I went to Honda and the advisor say is normal for Honda, but i just feel that the car should not have this kind of vibration. Nobody seem to know the problem.
Please help, no one seems to know what is causing this.
Any other ideas as to how to eliminate this vibration?
May 28, 2010 at 11:50 AM
