The following items are to be inspected:
Brake hoses and lines
front axles and CV joint boots
Exhaust system
Fluids and lubericant levels
Front Brakes
Fuel lines and connections
Lights and controls
Parking Brake
INSPECT AND ADJUST IF NECESSARY
Rear Brakes / system
Steering gear / Rack and Pinion
Steering Rack boots
Suspension
Tie Rod ends
Underbody inspection
LUBERICATE door hinges and locks
REPLACE motor oil and filter
Rotate tires
These are the items listed under the 100K service. As far as the transmission, the fluid should be a pinkish red color. If it is brownish or yellowish in color or has a burnt smell to it, then service it. You are welcome to contact me via this thread with questions.
Let me know, and thanks for using 2carpros.com.
Oct 27, 2018 at 5:49 PM
(Merged)
