[quote:05c567df26="mathiaso"]Hello lj050405
I have found the recalls you have mentioned.
There is a phone number for Honda you can call to clarify the problem with what the dealer said to you.
Honda Accord Recalls
Accord FUEL SYSTEM, GASOLINE:DELIVERY:FUEL PUMP Recall – ID# 47207
Recall Date
MAR 14, 2007
Model Affected
2005 HONDA ACCORD
Description
ON CERTAIN VEHICLES, A COIL WIRE INSIDE THE FUEL PUMP RELAY MAY BREAK, CAUSING THE FUEL PUMP TO LOSE POWER. IF THE FUEL PUMP BECOMES INOPERATIVE, THE ENGINE MAY NOT START.
Consequence
IF THE FUEL PUMP LOSES POWER WHILE DRIVING, THE ENGINE COULD STALL WITHOUT WARNING, AND A CRASH COULD OCCUR.
Remedy
DEALERS WILL INSPECT AND REPLACE THE FUEL PUMP RELAY FREE OF CHARGE. THE RECALL BEGAN ON APRIL 2, 2007. OWNERS MAY CONTACT HONDA AT 1-800-999-1009.
Potential Units Affected
166561
Accord ELECTRICAL SYSTEM:FUSES AND CIRCUIT BREAKERS Recall – ID# 26978
Recall Date
APR 05, 2005
Model Affected
2005 HONDA ACCORD
Description
ON CERTAIN PASSENGER VEHICLES, A LOOSE TERMINAL IN THE MAIN FUSE BOX MAY CAUSE THE FUEL PUMP TO LOSE POWER. IF THE FUEL PUMP BECOMES INOPERATIVE, THE ENGINE MAY NOT START.
Consequence
IF THE FUEL PUMP LOSES POWER WHILE DRIVING THE ENGINE COULD STALL WITHOUT WARNING WHICH COULD RESULT IN A CRASH.
Remedy
DEALERS WILL REPLACE THE ENTIRE FUSE BOX FREE OF CHARGE. THE RECALL BEGAN ON APRIL 13, 2005. OWNERS MAY CONTACT HONDA AT 800-999-1009 OR ACURA AT 1-800-382-2238.
1923[/quote:05c567df26]
Hi there,
Actually I already called American Honda and they said my car is not apart of the recall. Does this sound like something that would be a consequence of the issues with the recall? They certainly did not care when I called and told them.
Would the ABS and emergency brake light flash? Would the car lose all power including electrical?
Aug 16, 2019 at 2:04 PM
(Merged)
