I noticed a few days ago that the oil dip stick was showing the oil level above the maximum marker. in addition I felt that the coolant level was also low, so I took the car to the nearest honda dealership. Anyhow, they apparently sorted out everything. but when I cam back home, the oil level on the dip stick was still a bit higher than the max level. Also the coolant level seemed a bit low although it does appear to be in line with the max level. Maybe I might be confused at seeing the coolant tank half full. could you kindly help me out in these two issues...please. Thank You in advance.
Jan 13, 2008 at 3:22 PM
