Seems the new switch is malfunctioning as well resulting in the clicking noise.
CLUTCH PEDAL, CLUTCH PEDAL POSITION SWITCH, AND CLUTCH INTERLOCK SWITCH ADJUSTMENT
NOTE:
"¢ Check the clutch pedal position switch.
"¢ Check the clutch interlock switch.
"¢ Remove the driver's floor mat before adjusting the clutch pedal.
"¢ The clutch is self-adjusting to compensate for wear.
"¢ If there is no clearance between the master cylinder piston and push rod, the release bearing will be held against the diaphragm spring, which can result in clutch slippage or other clutch problems.
1. Loosen the clutch pedal position switch locknut (A), and back off the clutch pedal position switch (B) until it no longer touches the clutch pedal (C).
2. Loosen the clutch pushrod locknut (D), and turn the pushrod (E) in or out to get the specified height (F), stroke (G), free play (H), and disengagement height (I) at the clutch pedal.
Clutch Pedal Stroke: 130-140 mm (5.12-5.51 in.)
Clutch Pedal Free
â—¦ Play: 10-18 mm (0.39-0.71 in.)
Clutch Pedal Height: 191 mm (7.52 in.)
Clutch Pedal
â—¦ Disengagement Height: 95 mm (3.74 in.)
3 Tighten the clutch pushrod locknut.
4. With the clutch pedal released, turn in the clutch pedal position switch until it contacts the clutch pedal.
5. Turn in the clutch pedal position switch an additional 3/4 to 1 turn.
6. Tighten the clutch pedal position switch locknut.
7. Press the clutch pedal to the floor.
8. Release the clutch pedal 9-12 mm (0.35-0.47 in.) from the fully pressed position, and hold it there. Adjust the position of the clutch interlock switch (K) so the engine will start with the clutch pedal in this position.
9. Tighten the clutch interlock switch locknut.
Jul 7, 2010 at 10:11 AM
