Fuel Pump Reset Switch
2004 HONDA ACCORD
MSCHOAF
Is there an emergency fuel pump shut off when the car is towed or in an accident? If so, how is the switch reset so that the fuel pump will work again?
Nov 14, 2008 at 10:23 AM
KHLOW2008
  • 41,814 POSTS
Hi MSchoaf,
There are no reset switches and if the fuel pump does not work, you need to check if power supply is available to the pump. If yes, the pump is faulty and needs to be replaced.
If power supply is not available, you need to check the PGM-FI main relay and fuel pump fuse.
Nov 17, 2008 at 7:02 AM
SERGIO VEGAS
yes, it have under the steering wheel, rear de plastic, you dont need to remove anything
Nov 5, 2023 at 11:35 PM
Do you have an image because I don't see the switch in the fuel pump wiring diagrams. Check out the images (below). Please let us know how it goes.
Nov 6, 2023 at 8:42 AM
