2003 Honda Accord Honda Accord Sat Nav
2003 HONDA ACCORD
67,149 MILES • 4 CYL • 2WD • AUTOMATIC
LEOSTAR902
Hiya Guys
Im glad I have found your website as you seem to be spot on. I have a Honda Accord 2.4 Exec Auto made in 2003 which has been off the road for about 14months while I was out of the country. In that time the car had never been starting resulting in the battery being replaced all is well apart from the sat nav as is is not aquiring the gps signal. I have tried several different locations, taking the battery off to try and reset the memory of the sat nave but nothing seems to work. How can this be resolved as this was working fine prior too the 14months.
Eagerly awaiting your reply, regards
Leo
Oct 21, 2009 at 3:56 PM
KHLOW2008
  • 41,814 POSTS
Hi Leo,
See if the following answers your question.
ANTI -THEFT FEATURE
The navigation system and audio unit have a coded theft protection circuit. Be sure to get the customer's anti -theft security codes number before;
• disconnecting the battery.
• disconnecting the navigation unit 8P connector.
• removing the No. 7 (10 A) fuse from the under-dash fuse/relay box.
After service, reconnect power to the navigation unit, and turn the ignition switch ON (II). Enter the 4 -digit anti -theft security code, then select "Done". If the code cannot be found, use the interactive network (iN) to look it up. You will need the serial number from the navigation unit in the trunk. It is on a label on the underside of the unit. Alternatively, you can view the serial number in the "Navi ECU" diagnostic screen (see NAVI ECU ).
When replacing the navigation unit, be sure to give the customer the new anti -theft security code.
© 2008 Mitchell Repair Information Co., LLC.
Oct 25, 2009 at 10:26 AM
