Clunking / crackling noise coming from driver side when turning right and also under hard acceleration going straight. Only lasts a couple of seconds. Already changed c.v joints, spindle, hub assembly, lower control arm, brake calipers on both sides. Running out of things to change, but noise is still there. Have had the transmission checked, it is okay. Tried to press brake and gas at the same time to see if it is motor / transmission mounts but that is fine as well. Any idea as to what would cause this sound?
Jan 29, 2010 at 3:37 AM
