2003 Honda Accord 2003 Accord Vibrates at 60 mph
2003 HONDA ACCORD
79,000 MILES • 4 CYL • FWD • AUTOMATIC
STATE09
I have a 2003 Honda Accord EX coupe. Just recently it began vibrating when I accelerate and reach 60 mph. When I let of the gas the vibration stops. The vibration is felt underneath the seats. there is no vibration in the steering wheel. I've done the followng in the order listed to attempt to fix the problem, but it still exists.
1) Wheel Alignment
2) Tire rotate and balance
3) replacement of axles with newly manufactured ones
4) 4 new tires, balance and wheel alignment
After all this my car still vibrates and every technition I take it to says it must the the axles. The have check my wheel bearing and motor mount and don't see that they could be causing the problem. They say my problem points directly to the axles. Well, I just got new axles put on and it doesn't fix the problem. Please help!!!
Jul 27, 2009 at 7:01 PM
F4I_GUY
  • 3,302 POSTS
usually it is the axles. But since you have replaced them (assuming they aren't defective) I would take a good hard look at your mounts.
Feb 21, 2019 at 1:10 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
I would also check the mountings and from experience any body vibration not felt in the steering is normally something at the rear, tyres, rear alignment,
Mark (mhpautos)
