2002 Honda Accord unusual shaking
2002 HONDA ACCORD
158,000 MILES • 6 CYL • 2WD • AUTOMATIC
DRIFTBABE24
hey guys,
My 2002 honda accord (v6) started recent;y shaking and wobbling when I started to engine (while in parking and in movement). I never felt it before, so I took it to the mechanic. He changed the motor oil, filter, etc. He didn't change or add and transmission fluid, however, I had someone else do it, thinking that I would fix the problem. He said the car was in need of transmission fluid indeed, but the shaking could be coming from one of the tires. He said two of them needed more air. I put more air, but the car still shakes, same or worse than before. It feels like Im running on empty tires, or a bumpy road. Also, Im noticing my breaks are not as reliable as before, making me feel unsafe in my "once in great performer" car.
help please.
thanks[img:bcbad7ce05]http://www.2carpros.com/forum/automotive_pictures/432539_IMG00140200906131001_1.jpg[/img:bcbad7ce05]
Nov 8, 2009 at 8:48 PM
IF you feel it when the car isn't moving (according to your posting) then chances are it has nothing to do with the trans, tires, and most certanily the oil change. Can you describe it. When you rev the engine in park, do you feel it? Has the check engine light come on?
Nov 8, 2009 at 10:27 PM
DRIFTBABE24
yes the "check engine" light has come on and thats why I took it to the mechanic, but when I took it to the mechanic for a "routine check up" the shaking wasn't happening. It is slight when on parking and becomes more unsettled as I speed.
thanks
Nov 8, 2009 at 11:10 PM
HONDA TECH 1818
  • 536 POSTS
I think your engine has a misfire.
Nov 9, 2009 at 1:21 AM
