2002 Honda Accord timing belt
2002 HONDA ACCORD
73,000 MILES • 6 CYL • 2WD • AUTOMATIC
when should I replace timing belt and water pump? I know how important timing belt is and want to play it safe. I live in a hot weather city.
Nov 27, 2008 at 9:27 AM
BMRFIXIT
  • 19,053 POSTS
85 to 105 k
2002 Honda Accord
In-Line4   -
 Normal Maintenance Details
Add Detail Lines as Notes Please Note: Maintenance detail items may include multiple vehicle configurations. Therefore, it may be necessary to edit the detail items on the worksheet. 105,000 Miles (168,000 Kilometers) : All Applicable Models
OPERATIONCOMPONENT
INSPECT BRAKE HOSES & LINES Including ABS.
INSPECT DRIVESHAFT/PROPELLER SHAFT DUST BOOTS
INSPECT ENGINE COOLING SYSTEM HOSES & CLAMPS
INSPECT EXHAUST SYSTEM
INSPECT FLUID & LUBRICANT LEVELS
INSPECT FRONT BRAKE SYSTEM
INSPECT FUEL LINES & CONNECTIONS
INSPECT IDLE SPEED
INSPECT PARKING BRAKE Adjust if necessary.
INSPECT REAR BRAKE SYSTEM
INSPECT STEERING GEAR/RACK
INSPECT STEERING RACK BOOTS
INSPECT SUSPENSION COMPONENTS
INSPECT TIE ROD ENDS
INSPECT VALVE CLEARANCE Audible inspection only. Adjust only if noisy.
INSPECT WATER PUMP
REPLACE ENGINE OIL
REPLACE ENGINE OIL FILTER
REPLACE SPARK PLUGS
REPLACE TIMING BELT
ROTATE TIRES
105,000 Miles (168,000 Kilometers) : In-Line4
OPERATIONCOMPONENT
REPLACE BALANCER BELT
Nov 27, 2008 at 10:23 AM
