2002 Honda Accord TCS and Check Engine (P1607) are ON simul
2002 HONDA ACCORD
7,000 MILES • 6 CYL • FWD • AUTOMATIC
NUENDO
2002 Honda Accord v6; 7,000 Milles.
TCS and Check Engine (P1607) are on simultaneously.
Driving with these two lights on is a disaster. It takes time to accelerate the car with 2500 RPM.
I am not able to reset the Check Engine by Code scanner. I have to drive for about 3 miles and make a stop. Restart engine then TSC goes away, but Check Engine still on, then I use Code scanner and reset the Check Engine.
When these two light are off, the car runs like a champion. On the next day TCS and Check Engine (P1607) are on again.
Please help me to resolve this issue…
Mar 17, 2009 at 10:41 PM
KHLOW2008
  • 41,814 POSTS
Hi nuendo,
DTC P1607: ECM/PCM INTERNAL CIRCUIT MALFUNCTION
1. Reset the ECM/PCM
2. Turn the ignition switch ON (II).
3. Wait 30 seconds.
Is DTC P1607 indicated?
YES - Substitute a known-good ECM/PCM and recheck . If the symptom/indication goes away, replace the original ECM/PCM.
NO - Go to step 4.
4. Turn the ignition switch OFF.
5. Turn the ignition switch ON (II).
6. Wait 10 seconds.
YES - Substitute a known-good ECM/PCM and recheck. If the symptom/indication goes away, replace the original ECM/PCM.
NO - Intermittent failure, system is OK at this time.
© 2008 Mitchell Repair Information Co., LLC.
Mar 18, 2009 at 2:44 PM
