Speedometer not working
2002 HONDA ACCORD
100,500 MILES • 6 CYL • FWD • AUTOMATIC
CBOCCIA
I just had the battery replaced in my car at an Advanced Auto parts. When I left the parking lot I noticed my speedometer was not working and the radio was asking for a code. I know the reason for the radio, but is the speedometer problem a coincidence or could they have possibly done something to it when they were installing the new battery?
Feb 20, 2009 at 6:48 PM
MASTERTECHTIM
  • 4,750 POSTS
its possible. the vehicle spped sensor is located on top of the transmission and if they were yanking on the battery cables they could have popped off the connector to the vehicle speed sensor
Feb 20, 2009 at 8:57 PM
KALEO707
  • 4 POSTS
Electrical problem
2001 Honda Accord 4 cyl Front Wheel Drive Manual
Recently my speedometer stopped working,I checked through the book to see if it could of been a fuse but was not too sure what i was looking for,The RPM's worked aswell as the gas gauge,just not the speedometer.Also the check engine light stays on.Any advise?
Jul 14, 2020 at 12:59 PM (Merged)
Could be the vehcile speed sensor-CEL on scan the computer for OBD2 code/s
KALEO707
  • 4 POSTS
Im not too sure on how about going and doing that,can you give me a little bit more info? I appreciate it!
Your check engine light is on-it means the computer has identified a problem in the engine managment system you need to have it scanned and then comeback with the code/s
KALEO707
  • 4 POSTS
now how should i go about getting it scanned,im just trying to figure out the best and most economical way of doing this...GREAT INFO THOUGH AND GREATLY APPRECIATED!!!!
ARIELHERNANDEZ
My speedometer and odometer stopped working. The vehicle is running without any problems. Is This a sensor problem? If so where is it located.
Thanks
You can take to autozone and get scanned its a free service this is your starting point finding out what's wrong
JDL
  • 16,098 POSTS
Any applicable trouble codes? There is a vehicle speed sensor, vss. I'd check voltage and ground at the sensor. Fuse 6-- 15 amp goes hot when you turn on the key, not only check the fuse, check for voltage on the fuse circuit.
https://www.2carpros.com/forum/automotive_pictures/170934_honda_accord_vss_1.jpg
KALEO707
  • 4 POSTS
Thanks man thats exactly what i wanted to hear.I greatly appreciate your info and timely answers!! Have a great day!
JJMORRELLI
I just changed my spark plugs and disconnected the battery to clean the terminals. When I went to test drive the car. The speedometer was not working?
Suggestions?
Check the vehicle speed sensor
JJMORRELLI
where do i find that?
Check on the top left of the transaxle
