2002 Honda Accord front outboard brake pad worn
2002 HONDA ACCORD
1CM2
2002 Honda Accord
I just put front pads on 1 year ago. inboard pad on right side looks new. Outboard pad very worn. What would cause this?
Mar 27, 2009 at 9:38 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:a45acf2765="1cm2"]2002 Honda Accord
I just put front pads on 1 year ago. inboard pad on right side looks new. Outboard pad very worn. What would cause this?[/quote:a45acf2765]
Most likely it is the caliper housing bolts are stuck holding to outer pad against the rotor.
Mar 27, 2009 at 9:48 PM
1CM2
Thanks, I didn't turn the rotors and then noticed the pedal pulsating at high speeds. Mighta had somethin to do with it. Took em off this time, carried them 2 miles to get turned; should be good this time.
Mar 28, 2009 at 6:25 PM
1CM2
I ended up putting 25 year-old High temp disc brake bearing grease on the caliper pins. I remember getting the can and it's been laying around here since. Hope that'll work.
When I got it apart, I saw the pads were evenly worn. At first glance through the caliper, that's what I thought I saw.
Mar 28, 2009 at 10:14 PM
