Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Honda
Accord
Drivetrain
Bearing Hub
2001 Honda Accord rear hub assembly
2001 HONDA ACCORD
40,000 MILES • 6 CYL • FWD • AUTOMATIC
MFERRARO02
MEMBER
1 POST
FOLLOW
Does the rear hub asembly need to be pressed off and on the spindle to replace it or is it a slip fit on and off?
May 17, 2009 at 8:24 PM
KHLOW2008
CERTIFIED EXPERT
Hi mferraro02,
The rear hub comes as an assy with the bearings and is installed as a unit. No disassembly and assembly of unit is required.
After removing the brake caliper and mount and the rotor, removing the central bolt would allow you to remove the hub assy.
May 24, 2009 at 12:45 PM
