2001 Honda Accord rear hub assembly
2001 HONDA ACCORD
40,000 MILES • 6 CYL • FWD • AUTOMATIC
MFERRARO02
Does the rear hub asembly need to be pressed off and on the spindle to replace it or is it a slip fit on and off?
May 17, 2009 at 8:24 PM
KHLOW2008
  • 41,814 POSTS
Hi mferraro02,
The rear hub comes as an assy with the bearings and is installed as a unit. No disassembly and assembly of unit is required.
After removing the brake caliper and mount and the rotor, removing the central bolt would allow you to remove the hub assy.
May 24, 2009 at 12:45 PM
