2001 Honda Accord Front brakes sucks.
2001 HONDA ACCORD
75,000 MILES • 4 CYL • 2WD • AUTOMATIC
HRHRQ8
hi.i have honda accord coupe 2001, well i bought it used and i have problem with front brakes.when i press brake little hard i hear like hard metal rubbing sound and seems front brakes are given more preasure thats why the car bents front word down. after a long drive i checked the rims by touching and found front rims are too hot as compare to rear.
i have visited to repair center to check wether pads are gone but all pads are fine...
is there problem with ABS or fluid is not evenly destributed to all brakes ?? need help.
Mar 3, 2008 at 11:29 AM
JEREMIAH
  • 217 POSTS
it is necessary to have more braking force applied to the front of the vehicle since that is where the engine and transmission is located which is the bulk of the vehicle's weight.
the noise is made by the brake's rotor and pad surfaces making contact. either due to the material of the brake pad itself or because grease got on the rotor when the pads were replaced.
either bad part or poor job.you might be able to fix it by cleaning the rotor surface unless you want to replace the pads and resurface the rotor.
Mar 3, 2008 at 12:16 PM
