While driving on the freeway, I happened to drop RH side glass out of the passenger side (blind spot) powered, foldable and non heated assembly.
I purchased the new glass assembly with a plastic backing a guinine part from Honda dealer. I am finding difficulty in assembling it with the actuator. There are two mini motors. Each has a ball type actuating rod. Being a blind assembly, I am not able to insert the ball in the plastic socket at the back of the glass frame.
Is there a special tool or any technique to assemble it securely? Please advise.
Thanking you,
Thanking you,
Apr 5, 2009 at 4:09 PM
