How do you get to the front drivers side turn signal to change the bulb?
2000 HONDA ACCORD
130,000 MILES • 4 CYL • 2WD • MANUAL
TIM HENRY
Feb 28, 2009 at 4:17 PM
KHLOW2008
  • 41,814 POSTS
Hi Tim, The diagrams shows the signal wire connector for the turn signal which has a small access hole. If you are unable to get at the bulb socket through it, then you need to partially remove the fender liner (from under wheel arch at tire) to gain access.
https://www.2carpros.com/forum/automotive_pictures/192750_Headlight00Accord_1.jpg
May 17, 2021 at 12:38 PM
