Car stalls while driving on highway
2000 HONDA ACCORD
CGALATIOTO
Engine Performance problem 6 cyl Front Wheel Drive Automatic 105000 miles
I have been having issues with my 2000 Honda Accord stalling usually in stop and go traffic, or recently while on the highway at 70mph. I notice the engine sluggish and the throttle unresponsive. This is not an electrical problem because the engine remains on, only i cannot get any response when i step on the gas. There is currently a recall on the ignition switch, which i am ineligible for. This problem happens randomly.
Weirdly this happens most when there is luggage in the trunk or the trunk is over loaded. Is there a sensor in the trunk somewhere that affects the fuel pump? Usually happens after the car has been running for a while.
No check engine lights, diagnostic showed nothing wrong.
I have been researching, and found similar problems related to ignition switch, or main fuel relay, or fuel pump.
Any help would be appreciated, i am taking it in for service tomorrow and going to start with the ignition switch, and see what he says. I trust the mechanic but would like to pin point the problem to save some money.
Thanks for you help in advance.
Jun 2, 2009 at 10:05 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Don't think ignition switch is at fault. More inclined to suspect fuel pump. When car does this will it just snap back or do you have to stop and restart?
Let me know
Thanks for donate
Jun 3, 2009 at 9:47 AM
CGALATIOTO
No well if i am starting the car it will start, then idle down sputter and die, i then have to release pressure from gas tank (dont ask why it helps) then wait a while and eventually it will start up again.
The other day i was on the highway, and the gas was just not responding and i had to coast from 70mph down to about 15 then it stalled, and i did the same trick and got it going again.
The car is very sluggish during all of this while driving. I thought it was the ignition switch or coil since there is a recall. But now i think it could be the main relay that feeds to the fuel pump.
The car is in the shop as of this morning, so any advice i can call the mechanic and tell them to check.
Of course i drove it last night, nothing in the trunk just myself and the performance and stalling was fine. Like i said its intermittent and doesnt happen all the time which is a pain in the ass.
Thanks for your help, it is greatly appreciated.
Jun 3, 2009 at 10:03 AM
DOCFIXIT
  • 18,828 POSTS
The fact when you relieve pressure in tank and it starts points to fuel pump. Does this problem occure more when tank is less than 1/2 ?
Jun 3, 2009 at 10:11 AM
HYPERMIK
My 2001 Accord Coupe (170K) has been stalling for over year. There was never any indicators why it would do this but it finally didn't start back up and that's when they found the MAIN RELAY was down. They said it didn't show up on the computer before because it would only shut off for a minute when the car dies then come back on. Easy self fix for $40-50 at NAPA. This drove me crazy so I hope this help everyone.
Jun 22, 2010 at 7:55 AM
CGALATIOTO
To follow up... The MAIN RELAY was the fault of this issue and the car is now fixed. Has been running fine for about a year.
Jun 22, 2010 at 8:53 AM
