2000 Honda Accord BUSHINGS
2000 HONDA ACCORD
105,000 MILES • 4 CYL • 2WD • AUTOMATIC
GERENA339
CAN BUSHINGS INTERFERE WITH THE BALANCING OF A CAR? I HAD A FOUR WHEEL BALANCE JOB BUT FIRST HAD TO REPLACE A BAD DRUM, TWO BAD TIRES AND A OXIDIZED SCREW OF THE REAR CONTROL ARM. NOW IT WAS DISCOVERED THAT THE BUSHING HAD TO BE REPLACED. WOULD THIS BE EXPENSIVE PART AND LABOR?
May 7, 2010 at 3:42 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
The bushes are not that expensive depending on the type and brand, there will be a few hrs labour to do each side and there will be a rear wheel alignment check to be done, if in doubt go get a few quotes and com pair prices.
mark (mhpautos)
May 7, 2010 at 9:26 PM
