2000 Honda Accord A/C COMPRESSOR NOT WORKING (NO POWER OR
2000 HONDA ACCORD
90,000 MILES • 6 CYL • FWD • AUTOMATIC
DILLARD
A/C COMPRESSOR NOT WORKING. CHECK TO SEE IF IT HAD POWER TO COMPRESSOR AND FOUND THAT IT HAD NO GROUND. PUT A TEST LIGHT TO GROUND FROM BATTERY TO CONNECTOR OF PRESSURE CYCLING SWITCH AND COMPRESSOR COMES ON AND READINGS ARE PERFECT. CHECKED ALL FUSES AND RELAYS AND REPLACE PRESSURE SWITCH AND CLUTCH RELAY AND STILL NO COLD AIR (COMPRESSOR STILL NOT ENGAGING. HELP-HELP !!!!
Sep 9, 2008 at 8:57 PM
KHLOW2008
  • 41,814 POSTS
Hi DILLARD,
Thank you for the donation.
The AC clutch relay grounding is via the PCM so you need to check the connections. Might be a faulty PCM
Sep 10, 2008 at 1:49 PM
