2000 Accord all door ajar lights on, brake and volt warning
2000 HONDA ACCORD
LOBOGUARA
I have no idea what would cause this...2000 Accord LX 4dr, and this only started happening after a few particularly icy, then rainy days.
While driving, seemingly as the car is jostled, all of the door-ajar warning lights, the trunk open warning, and brakelight warning light will come on, as well as the voltage warning and parking brake warning. Nothing else is affected, and the car drives normally.
When the car is bumped or goes up/downhill, these lights will all flicker and go off, back on, flicker dimly, on, off again, all at once. When they're off, the brake and door ajar lights function properly with their sensors.
I strongly suspect that a harness that has to be connected to keep them "off" is loose, but I can't find which one it is...the one behind the instrument cluster, one under the dash? Any ideas, or anything else it could be?
Jan 12, 2006 at 3:29 PM
2CARPRO JACK
  • 11,533 POSTS
Try the wiring at or near the alt. Also check the battery
Jan 18, 2006 at 5:09 PM
