1999 Honda Accord window washer pump
1999 HONDA ACCORD
164,783 MILES • 6 CYL • FWD • AUTOMATIC
DECRY
How do you change out a window washer pump?
Mar 11, 2009 at 4:07 PM
KHLOW2008
  • 41,814 POSTS
Hi decry,
You need to gain access by removing the washer tank and unplugging it :
Remove left inner fender.
Remove bolts and washer fluid reservoir.
Disconnect hose(s) and 2-pin connector(s) from washer motor(s).
Remove deflector, washer nozzles, and washer fluid hoses as necessary.
To install, reverse removal procedure.
Mar 16, 2009 at 1:05 PM
