1999 Honda Accord steady speed
1999 HONDA ACCORD
147,000 MILES • 6 CYL • 4WD • AUTOMATIC
STR8NDIRECT
  • 6 POSTS
Okay, I have a 99 Honda Accord.For the last few months a type of stalling,bucking,jerking type trouble.I went to two different mechanics and they said it was the EGR passageways. So I had the honda dealerships clear the passageways.Still...same problem.I took the car to honda and got another scan.And they said it cylinder misfires.So I spent around 600 for them to fix that...and replace something with the ignition and housing distributor.Then they reccommend I get a catalytic converter to help with the acceleration because it wouldn't go faster than 10 miles an hour.So I get that AND IT STILL BOGS,STRAINS,HAS TROUBLE KEEPING ONE STEADY SPEED WITHOUT JERKING.Now they say it is an O2 sensor...HELLPPPP?...that is all...thank you
Jul 1, 2008 at 12:34 AM
MERLIN2021
  • 17,250 POSTS
Usually it turns out to be either the PCM ground, or a bad MAF, you can try this first tho, comes right from Honda to thier Techs...
https://www.2carpros.com/forum/automotive_pictures/62217_Capacitors_1.jpg
Jul 1, 2008 at 7:52 AM
KHLOW2008
  • 41,814 POSTS
Hi str8ndirect,
The O2 sensor can cause problem with jerking, mifiring, lack of acceleration etc.
Another thing to test is the throttle position sensor.
Jul 1, 2008 at 10:24 AM
STR8NDIRECT
  • 6 POSTS
After getting the car scanned 4 possible reasons were causing the problem.Maf sensor.....oxygen sensor,ignition misfire,or fuel injecto problem.Andy suggestions?
Jul 1, 2008 at 3:05 PM
KHLOW2008
  • 41,814 POSTS
Hi str8ndirect,
Honda uses MAP sensor instead of MAF and it is quite reliable.
I would go for the O2 sensor first. Misfiring could be due to the EGR and is related to the O2 sensor.
Jul 2, 2008 at 6:40 AM
STR8NDIRECT
  • 6 POSTS
I have had my egr replaced twice.And had the egr passageways cleaned.If it's not the O2 sensor what's my next guess?
Jul 2, 2008 at 3:06 PM
KHLOW2008
  • 41,814 POSTS
Hi str8ndirect,
Does the jerking only appears at between 1800 to 2200 rpm?
I have envounterd cases of it happening and it was the EGR valve working with the purge solenoid clicking away.
Check throttle position sensor reading, 0.5 v at fully closed and 4.5 at fully opened throttle. transition from close to open should be smooth. You might need to check the catalytic converter too.
Jul 3, 2008 at 6:00 AM
STR8NDIRECT
  • 6 POSTS
I have absolute no idea what a solenoid is.And I have have the EGR replaced twice,and just recently got a catalytic converter.The converter helped it accelerate better but I still have trouble keeping steady speeds.I keep hearing it might be the fuel regulator or the o2 sensor.Your thoughts?
Jul 3, 2008 at 7:45 PM
MERLIN2021
  • 17,250 POSTS
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Go here and checkout our video.
Rent the tool at Autozone. Was the 02 code for lean operation P0171?
Jul 3, 2008 at 8:03 PM
STR8NDIRECT
  • 6 POSTS
[quote:aebdc3ecf4="merlin2021"]https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Rent the tool at Autozone. Was the 02 code for lean operation P0171?[/quote:aebdc3ecf4]
Actually yes it was.I got a code p0170 and p0171.I was told that it could be the o2 sensor or a fuel pressure regulator that could fix the problem.Any cheap way to know for sure?(yes it has been awhile...still unable to get it fixed)
Aug 20, 2008 at 3:15 AM
MERLIN2021
  • 17,250 POSTS
Uplug the vacuum line, can you smell or see gas? If yes replace it,(FPR) If the regulator looks ok, with 147,000 if the O2 hasnt been done yet, most are good for 100,000...
Aug 21, 2008 at 5:47 PM
STR8NDIRECT
  • 6 POSTS
I have no idea what the vacuum line is,or looks like.Mind explaning how to locate it and unplug it?
Aug 21, 2008 at 10:08 PM
MERLIN2021
  • 17,250 POSTS
FUEL PRESSURE TEST Special Tools Required  Fuel pressure gauge 07406-0040001  Fuel pressure gauge attachment 07VAJ-0040100 1. Relieve the fuel pressure (see Fuel Pressure Relieving ). 2. Use a wrench to remove the fuel pulsation damper from its fitting, then attach the fuel pressure gauge attachment. Fig. 3: Removing Fuel Pulsation Damper Courtesy of AMERICAN HONDA MOTOR CO., INC. 3. Attach the fuel pressure gauge. Fig. 4: Attaching Fuel Pressure Gauge - '98-99 Models Courtesy of AMERICAN HONDA MOTOR CO., INC. Fig. 5: Attaching Fuel Pressure Gauge - '00-02 Models Courtesy of AMERICAN HONDA MOTOR CO., INC. 4. Disconnect the vacuum hose (A) of the fuel pressure regulator and pinch it closed with a clamp (B). 5. Start the engine and let it idle.  If the engine starts, go to step 7 .  If the engine does not start, go to step 6. 6. Check to see if the fuel pump is running: remove the fuel fill cap and listen to the fuel fill port while an assistant turns the ignition switch ON (II). You should hear the pump run for about 2 seconds when the ignition is turned ON (II).  If the pump runs, go to step 7.  If the pump does not run, test it (see FUEL PUMP TEST ). 7. Read the pressure gauge (with the fuel pressure regulator vacuum hose disconnected and clamped). The pressure should be: '98-00 models: 280-330 kPa (2.9-3.4 kgf/cm 2 , 41-48 psi). '01-02 models: 320-370 kPa (3.3-3.8 kgf/cm 2 , 48-54 psi).  If the pressure is OK and the engine is running, go to step 8. If the engine is not running, repair the cause, then continue this test.  If the pressure is out of spec, go to step 9 . 8. With the engine running, reconnect the vacuum hose, and read the gauge again. The pressure should be: '98-00 models: 220-270 kPa (2.25-2.75 kgf/cm 2 , 32-40 psi) '01-02 models: 260-310 kPa (2.7-3.2 kgf/cm 2 , 38-46 psi)  If the fuel pressure is OK, the test is complete. Go to step 10 .  If the pressure is out of spec, go to step 9. 9. Disconnect the vacuum hose from the pressure regulator again while you watch the pressure gauge. The pressure should rise when you disconnect the hose.  If the pressure did not rise, replace the fuel pressure regulator (see Fuel Pressure Regulator Replacement ), and recheck the fuel pressure.  If the pressure rose, and all your readings were within spec, go to step 10.  If the pressure rose, but your readings were out of spec, check for these problems:  If the pressure is too low, check for a clogged fuel filter and for leaks in the fuel lines.  If the pressure is too high, check for a pinched or clogged fuel return hose or line. 10. Reconnect the vacuum hose, remove the pressure gauge, and reinstall the fuel pulsation damper with a new washer. Tighten the fuel pulsation damper to 22 N.m (2.2 kgf.m, 16 lbf.ft). NOTE: Disassemble and clean the fuel pressure gauge attachment thoroughly after use.
https://www.2carpros.com/forum/automotive_pictures/62217_Hondab_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_Handa_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_hondac_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_hondad_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_hondae_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_hondaf_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_hondag_1.jpg
Aug 23, 2008 at 6:50 AM
