1999 Honda Accord P1149 H02S
1999 HONDA ACCORD
199,000 MILES • 4 CYL • FWD • AUTOMATIC
HONDAGAL
Hi, I have a 99 Accord that was jerking and hesitating when i accelerated. The dealer diagnosed as having a P1149 Ho2S (Primary HO2 Sensor 1) issue. They said according to the Technical Service Bulletin #01-031 which says to replace the ECM/PCM. How much should this cost to replace this? I am worried I will overpay. Also is it safe to drive the car with this problem (check engine light is on)? Thanks so much, I really appreciate it!
Sep 30, 2008 at 12:14 AM
2CARPRO JACK
  • 11,533 POSTS
I did find the TSB they are refering to, but my estimator doesnt give a price for the ecm. You are looking at about 1 hr of labor plus parts. Try calling other shops or Honda dealers and ask for "out the door prices" this is a cut and dry procedure with no need for "bump" calls(price increases).
Sep 30, 2008 at 8:08 AM
HONDAGAL
Thank you! is it safe to drive the car with this ECM/PCM needing to be replaced? thanks
Sep 30, 2008 at 9:14 AM
2CARPRO JACK
  • 11,533 POSTS
The TSB claims it is a false code, so there may not really be a problem.But I would have it taken care of just in case, you dont want to do any damage to the cat converters from the mixture being too far off
Sep 30, 2008 at 9:32 AM
