1999 Honda Accord oil changed
1999 HONDA ACCORD
97,003 MILES • 4 CYL • FWD • AUTOMATIC
PLAYERO
1-What is the procedure to reset the computer after the oil was changed?
what can cause run the car with the "engine check" light on ?
Mar 1, 2008 at 3:11 PM
2CARPRO JACK
  • 11,533 POSTS
With key off, press and hold SELECT/RESET button on dash. While holding button down, turn key on/engine off. Light will reset after 10 seconds with button down.
The check engine light is the cars computer telling you it has detected a problem with a monitored system. Have the PCM (computer) scanned for codes, Autozone will do it for free. If the PCM sees a problem it will store a code that will help in diagnosing the problem, get back with the exact codes
Mar 2, 2008 at 8:02 AM
