1999 Honda Accord How hard is it to remove and install cyli
1999 HONDA ACCORD
90,000 MILES • 4 CYL • 2WD • AUTOMATIC
NOSHO47
  • 4 POSTS
How hard is it to remove and install the cylinder head off a 99 accord? I have read the hayne's manual but i am kind of confused. is it necessary to remove the rocker arms and valves when i remove the head to get it machined to remove the spark plug that is stuck.
Jan 17, 2009 at 2:12 AM
KHLOW2008
  • 41,814 POSTS
Hi nosho47,
It is a job that I hate to do, involves a lot of work and having a poor back does not help.
Before we go to that, you mentioned a stuck spark plug, maybe we can try to sort that out and save you a lot of work. Can you explain to me what is the problem?
Jan 18, 2009 at 1:32 AM
NOSHO47
  • 4 POSTS
The previous owner that I bought the car from I think stripped the hex on the spark plug so he put JB Weld on his socket and let it set on the spark plug. I guess that did not work so he instead left it there just to keep the spark plug wire in place. So now I am stuck trying to get it removed. At first I thought it would be rubber but it is too hard to chip it away.
Jan 18, 2009 at 11:48 AM
KHLOW2008
  • 41,814 POSTS
Hi nosho47,
I believe it is possible to remove any foreign materials by chipping it away with a sharp chisel but to remove the spark plug might be another matter.
Would you like to give it a try? Get a sharp chisel and you would need a small hosed vacumn cleaner to remove the debris.
Being a VTEC the plug cylinders are rather deep so makes things more difficult. If it had been without the cylinder, it would be easier if you remove the rocker carriers.
Jan 18, 2009 at 12:46 PM
