1999 Honda Accord Head Gasket
1999 HONDA ACCORD
125,000 MILES • 4 CYL • FWD • AUTOMATIC
JTSTICKS
I have a 99 accord 4-cyl.125K, idle rough at low end in gear and gets sluggish above 4000RPM. I have oil in the radiator and overflow and dripping below the car (no normal oil leaking spots) went through 3+ quarts oil over 3000 miles/3 weeks. Oil change guy says it seems to be head gasket, does not seem to be any water or other fluid in the engine when I check to the dipstick. I am getting no smoke or smell and the radiator is more than full. Is it the head gasket?? is it tough to change on a honda 4cyl?? estimate cost???
Jan 13, 2008 at 12:39 PM
BLACKOP555
  • 10,386 POSTS
sounds like a bad headgasket, since the oil is in the radiator, and the rough low and high idle.
to confirm it do a compression test on each cylinder if one is more then 25% lower then the highest one then the gasket is definetely bad. its not a tough change but a few thousand job, espeically if the heads need to be re machined.
Jan 13, 2008 at 8:45 PM
