starter motor location?
1999 HONDA ACCORD
JAZZIJ
Where is the starter motor located?
Nov 24, 2007 at 12:11 PM
The starter is near the transmission here is a guide to help you walk through the steps with instructions in the diagrams below to help you with your car.
Check out the diagrams (Below). Please let us know what happens.
Nov 24, 2007 at 6:30 PM
HATETHERED
Thank you
Nov 25, 2007 at 1:49 PM
SUMMSTEVE
98 Honda Accord ex sedan, 167,000, it hesitated when I started it yesterday morning but ran fine all day, however this morning it will not start. It cranks and cranks, everything fine, lights, radios, power windows and such. Is this a bad starter and where is the starter located?
Apr 25, 2020 at 2:32 PM (Merged)
SYNCRAIT
  • 235 POSTS
if the engine is turning over the starter is doing its job the things you want to look for next is finding out if there is fuel and spark going to the cylinders.... you might just try doing a basic tune up IE. replace the spark plugs and make sure the wires are in good shape, change the oil and filters (oil, fuel, air) and see if that dosent help any.... lemme know good luck :)
G122500
1998 honda accord where is the starter located
KHLOW2008
  • 41,814 POSTS
On top of the transmission, below the distributor. If you follow the battery positive cable you would come to it.
MICHELLYB
Engine Performance problem
1997 Honda Accord 4 cyl Automatic
I NEED T REPLACE THE STARTER ON MY HONDA ACCORD. DO YOU HAVE ANY DIAGRAMS THAT SHOW WHERE THE STARTER IS LOCATED AND HOW TO REPLACE IT?
BLUELIGHTNIN6
  • 16,542 POSTS
If you have trouble finding starter motor, just follow positive battery cable down engine compartment, it leads to the starter.
NOTE:
The factory sound system has a coded theft protection system. It is recommended that you know your reset code before you begin.
REMOVAL:
Disconnect the negative battery cable.
Remove the wiring harness from the starter motor.
Disconnect the lower radiator hose from the bracket on the starter motor.
Remove the starter cable from terminal B located on the back of the solenoid.
Remove the black/white wire from the S (solenoid) terminal.
Unfasten the two bolts that mount the starter to the transaxle assembly, then remove the starter from the vehicle.
INSTALLATION:
Install the starter in the reverse order of removal. Tighten the starter mounting bolts to 33 ft. lbs. (45 Nm) and the wire terminal nut to 7 ft. lbs. (9 Nm).
When installing the heavy gauge starter cable, make sure the crimped side of the terminal end is facing out.
Enter the anti-theft code and radio presets.
ANNALISA BENACKA
1995 Honda Accord LX 2.1 Stick shift. I just want to know if the starter to my car is up on top(easy to get to) or underneath?
CARLUCCIJA
  • 29 POSTS
starters are on the side of the motor facing the transmission. yours maybe closer to the firewall to your car if its front wheel drive and easier to get to from underneath the car
RCATES
  • 4 POSTS
my ac doesnt work....i do not see any leaking from my hoses....what could it be?
FIXITMR
  • 9,990 POSTS
what kind of water? not coolant? AC dont work when did it stop working? have you tested refrigerant level/pressure?
RCATES
  • 4 POSTS
i assume its from my coolant for the motor cause im over heating, the ac hasnt worked since i bought it cause i cant get freon.
RCATES
  • 4 POSTS
the car is overheating and the water runs out too fast to get anywhere really.
FIXITMR
  • 9,990 POSTS
that big a leak should be detectable? have you tried to locate? starter is on left side front or rear of trans? could be soft plug or hard metal line?
RCATES
  • 4 POSTS
i dont know what those are?? could you elaborate? what is as soft plug?
FIXITMR
  • 9,990 POSTS
your best bet is to take to mechanic.
