1999 Honda Accord Distributor Replacement
1999 HONDA ACCORD
ITSJAIME
Electrical problem
1999 Honda Accord 4 cyl Front Wheel Drive Automatic
How do I replace the distributor?
Nov 4, 2008 at 3:24 PM
KHLOW2008
  • 41,814 POSTS
Hi itsjaime,
You need to remove the 3 holding bolts , disconnect the wire connectors ans pull out the distributor.
When installing, make sure the distributor legs are in the correct direction, it is off set and should slide in easily. Reverse instalation would make it very difficult to go in.
After installation, you need to check the ignition timing.
Nov 15, 2008 at 10:54 AM
