1999 Honda Accord Brake Lights
1999 HONDA ACCORD
296,578 MILES • 6 CYL • 2WD • AUTOMATIC
MTBARWICK
I have replaced bulbs, pedal stop switch and $80 module in trunk and I am still continuing to blow the stop light fuse under hood. I have tried a combination of lights in and out of connectors and the only one that does not blow the fuse is if I do not plug in the module in the trunk. I can't find an apparent ort at the connectors everything seems to be wrapped and taped tight. I did un wrap the wire going to the module but found nothing, Could the gearshift locking solenoid be bad?
Mar 29, 2010 at 8:30 PM
Hi mtbarwick, Welcome to 2carpros and TY for the donation
The green wire when it leaves the brake light failure sensor is shorted to ground-remove all the bulbs from both tail light assembly-Get an ohmmeter zero it. At the sensor put one lead on the green wire and the other lead to a good ground if the needle moves or as in a digital meter it gives a reading its an indication of a short circuit that will blow the fuse-finding the short can be a bear but if its me I'll run another wire from the sensor to the bulb socket-
Note: if the short is before the sensor it will blow the fuse obviously this is not the case-Good Luck
Mar 30, 2010 at 5:44 AM
BASMSTR7
I am going through similar problems, but I can't find the right fuse for my rear-passenger side brake light. Would you please tell me the name of this fuse?
Thanks
Jan 22, 2013 at 6:00 PM
