1998 Honda Accord Ignition key
1998 HONDA ACCORD
GGLLSS58
Electrical problem
1998 Honda Accord 4 cyl Front Wheel Drive Automatic
How do I get my ignition key unstuck?
Nov 27, 2008 at 8:38 AM
BMRFIXIT
  • 19,053 POSTS
All 1998 had a recall on the ignition interlock
and ignition cylinder was replaced in most cases too
check key for excessive wear ,if key is worn ,cut new key
if you still cant turn the switch with the new key or the switch feels stiff ,one or more of the tumblers may be worn .remove and replace
if you parks on a hill set E brakes
step on brake try to rock and turn
to check on the recall have your VIN ready and call your locale dealer
good luck
Nov 27, 2008 at 8:57 AM
GGLLSS58
my problem is not inserting and starting, but getting the key out of the ignition. The vehicle will turn off and it will restart and is driveable. But when I put it in park, the key will not come out. We took care of the recall situation several years back and have not had this problem until now.
Nov 27, 2008 at 9:23 AM
BMRFIXIT
  • 19,053 POSTS
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_92.jpg
Key interlock system prevents ignition key from being removed from ignition lock assembly unless shift lever is in Park. When ignition key is in ignition lock assembly, key interlock switch closes, providing voltage to key interlock solenoid and interlock control unit. If shift lever is not in Park (parking pin switch on), interlock control unit energizes key interlock solenoid by completing ground circuit. When key interlock solenoid is energized, ignition key cannot be removed from ignition lock assembly. Key interlock switch and key interlock solenoid are located on ignition lock assembly. Parking pin switch is located on bottom of shift lever. Interlock control unit is located behind left side of dash, near steering column.
Nov 27, 2008 at 10:14 AM
