1998 Honda Accord How do you realign the balance shaft for
1998 HONDA ACCORD
117,000 MILES • 4 CYL • FWD • AUTOMATIC
ROBERTV137
MEMBER
FOLLOW
Can anyone provide any information on how to realign the balance shaft for a 98 Honda Accord.
Regards,
Robert
Mar 5, 2009 at 11:10 PM
KHLOW2008
CERTIFIED EXPERT
Hi Robert,
Here are the diagrams.
Locking rear balancer shaft.
Aligning front balancer
Mar 6, 2009 at 9:27 AM
ROBERTV137
MEMBER
First I like to say thanks for your response.
There are 2 shaft. I already have the crank and cam shaft in line. I kind of understand the right balance shft. Do I leave the crank and cam shaft at TDC and then rotate the right shaft until it's align or do I rotate all shaft together. Once done, how about the left shaft. How is the left shaft suppose to align.
Thanks again,
Robert
Mar 6, 2009 at 11:15 AM
KHLOW2008
CERTIFIED EXPERT
The crankshaft should be aligned at TDC and with right shaft locked, the balancer shaft would not be turning.
Install and get the left shaft to match the other shafts. After installation of the belts, all shaft markings should match accordingly , crankshaft at TDC with camshaft aligned, balancer shafts as per diagrams.
Mar 7, 2009 at 6:24 AM
ROBERTV137
MEMBER
I followed the diagram and now have the balance shaft in line. I put all back together and the car is running like a champ.
