The heat control on my Honda is manual control. I have 5 push buttons to select the zones (no digital display) and 3 buttons for recirculate, A/C, and rear window defroster. The fan control works all the time however the other controls come and go. Sometimes they work fine, other times they do not work at all, and still other times they flash on and off. The main problem is when they are off you can no longer select the zone, A/C, or air temp. I picked up a used climate control module from a salvage yard and this one did not help or is even worse. Any ideas on what else I can check?
Thanks
Thanks
Jun 18, 2010 at 2:03 PM
