1998 Honda Accord 1998 honda accord
1998 HONDA ACCORD
271,000 MILES • 4 CYL • AWD • AUTOMATIC
DW326DW
My car starts normal when it is cold and after driving itfor awhile or soon as the engine heats up, i turn the car off and start it up again and the start is rough starting and at times it takes a few turns of the ignigtion to start and when it do start it start fluttering and about one minute or so it smoothes out and it runs like nothing wronk except when i stop at alight and take off it hesitates only in first gear and the engine seems tobe over heating, i changed the spark plugs and wire and distributor and i still have the problem can you help please.
Jul 5, 2008 at 9:24 PM
KHLOW2008
  • 41,814 POSTS
Hi dw326dw,
Difficul starting during warm engine could be caused by low fuel pressure since you have checked the electricals.
Check the main relay if fuel pressure is low.
If the engine is overheating, you need to check if coolant level is full in the radiator and are the fans working?
Jul 5, 2008 at 10:19 PM
