fuel pump location
1997 HONDA ACCORD
164,000 MILES • 4 CYL • 2WD • AUTOMATIC
YANTRIASA
Where is the fuel pump located in Honda Accord 1997 station wagon? Suddenly it won't start. I change the spark plug, I check the fuse for fuel pump and it's good. Now I suspect maybe the fuel pump. Help please??
Sep 21, 2010 at 2:50 PM
BLUELIGHTNIN6
  • 16,542 POSTS
may want to check fuel pump relay first as well, fuel pump is in the fuel tank. Here is a guide to help you change it out step by step.
Sep 21, 2010 at 5:48 PM
JOE35772
  • 4 POSTS
all i need is too find the location of the fuel pump, thanks.
Apr 3, 2019 at 12:30 PM (Merged)
JOE35772
  • 4 POSTS
its a honda accord 1992...
KHLOW2008
  • 41,814 POSTS
It is in the fuel tank.
JOE35772
  • 4 POSTS
sorry but its the location of the fuel pump RELAY
KHLOW2008
  • 41,814 POSTS
It is known as the PGM-FI main relay and is located located behind left side of dash.
JOE35772
  • 4 POSTS
thanks...
KHLOW2008
  • 41,814 POSTS
You're welcome.
Have a nice day.
BOB1948
Where is it located and whats the easiest way to change it? 1985 Honda Accord, Fuel Pump
BRUCE HUNT
  • 3,754 POSTS
Get the book for your car. The library might have it or an auto parts store.
Apr 3, 2019 at 12:31 PM (Merged)
LOSONE
  • 1,616 POSTS
[quote:b87a53f18b="Bob1948"]Where is it located and whats the easiest way to change it? 1985 Honda Accord, Fuel Pump[/quote:b87a53f18b]
The fuel pump is located in the gas tank. You can get to it from an access hole in the trunk. They are proud of the price, about $250.00
LONNIE PHILLIPS
Fuel pump was intermittently working. No gas at fuel injectors. Not sure if the selenoid is working or where it is located under the dash or hood. Does anyone know what color it is or what color of wires come out of it? Any help would be great!! Thanks
KHLOW2008
  • 41,814 POSTS
Hi Lonnie Phillips, Check the PGM-FI main relay.
https://www.2carpros.com/forum/automotive_pictures/192750_PGMFIRelay90Accord_13.jpg
BLITZ210
  • 4 POSTS
i have a 1987 Honda accord and it out of the blue just stopped getting any power at all to go to the fuel pump. I have a repair book but can't find any answers. What should i look for to fix the problem? i know the pump isn't bad and there is just no juice going back to it
Try direct power from battery to fuel pump-pump turns on check and test fuse no.11, fuel pump relay and main relay.
BLITZ210
  • 4 POSTS
we added a new fuel pump relay and it still doesn't work. would anything get damaged if we direct connected it to the batery and drove the car like that?
How about the main relay did you check and test? If you can rig it with a toggle switch go for it-no its not gonna do anything wiring it direct.
BLITZ210
  • 4 POSTS
where is the main relay? is it under the dash with the fuel pump relay?
KHLOW2008
  • 41,814 POSTS
Hi blitz210,
Fuel injected and carburetted models use different types of fuel pump relays.
The fuel pump relay for fuel injection model is incorporated into the main relay.
It is a seven pin dark grey or brown relay found underdash just above the driver side fuse box.
BLITZ210
  • 4 POSTS
It is carburated and we replaced the fuel pump relay and have checked all of the fuses and still nothing. Would it be best to use a jumper wire and do a direct connect to make it work?
Thanks
KHLOW2008
  • 41,814 POSTS
Hi blitz210,
It requires a signal from the ignition coil, is the tachometer working?
Btw if it has an ECU under the passenger seat, then it might be causing the problem.
You can use a jumper to make it work direct, but in case of an emergency, the fuel pump would still be working if the engine is cut off with the ignition switch on.
TUESDAY777
i have given my car a full tune up, checked all fire to engine, changed fuel filter and pump. and it still kepps cutinoff on me when it stops getin gas, or when its hot outside and i have run it all day it just stalls all the time. i always hear the fuel pump cut on when i turn the ignition. ive taken it to two people and they say they cant find anything wrong with it. i really love my lil car and would hate to let it go! i hope you can help me.
thank you
BMRFIXIT
  • 19,053 POSTS
when its not starting you need to check for spark and for fuel pressure
if no spark most likely its the module inside the distributor
and you need to replace it
KHLOW2008
  • 41,814 POSTS
Hi tuesday777,
If it is fuel that is not being supplied, try changing the main relay, many similar cases have been caused by the relay.
STEVEC217
I thought my car was out of gas because it suddenly stopped running. I added 5 gals and it started for about two minutes and died again. It will start when fuel is added to the carb but dies. It has been sitting for a year and the filter is most likely plugged but I don't know where it is.
KHLOW2008
  • 41,814 POSTS
Hi stevec217,
Fuel filter location.
Under hood, driver side, front side of strut tower, mounted on fenderwell in fuel line
I would check the fuel pump in fuel tank.
JCFARBER
Dear friends,
My 1985 Honda Accord is running pretty good considering it has 211000 miles. No major overhauls or parts, but exhaust, tires and spark plugs, wires, distributor cap and rotor button.
However, it still idles rough as if it cannot find 750 rpm. Also, I hear a distinct ticking in the region of the gas tank like a grandfather ticking. The car has somewhat poor take off and acceleration but once going, it runs good getting around 30mpgs.
Along with the rough idle is a smell of gas like it is running 'rich'. We have noticed that when the clicking sound is noticed, the carburetor shoots gas into the chamber.
My question is: Is the fuel pump going and getting weak, and if it is, is it a big job to replace it? Considering it's in the gas tank.
Thanks,
jcfarber
KHLOW2008
  • 41,814 POSTS
Hi jcfarber,
The fuel pump is located at lower front of the rear Left wheel arch and it is not a rotary type so there will be a ticking noise when it is operating. This is normal. Replacement does not require removal of fuel tank.
Rough idling could be due to many factors.
1. Different compression of cylinders.
2. Bad spark plugs, wires etc.
3. Leaking vacumn lines
4. Faulty/out of adjustment carburettor
PABSRAM
The fuel pump on my honda went out I understand it's located in the fuel tank, how would I go about to remove the fuel pump?
The fuel pump on my honda went out I understand-Do you hear it when key at On position if so check the fuel pressure-if not power issue-get back
TIMSMO
My honda accord makes a groaning noise for 5-6 seconds when I take a hard turn. The sound is coming from the trunk area. Is this probably a bad fuel pump and is the pump located in the gas tank?
Thanks!
KHLOW2008
  • 41,814 POSTS
Hi timsmo,
The fuel pump is in tank but groaning noise during hard turns are not likely to be due to it.
It is a problem most likely to be related to the suspension system.
Without the physical vehicle, it would be almost impossible to diagnose the problem and the only way is to try to locate the source.
TUNIT69
hello is fuel pump located in the tank on this car and what is the book time for changing it also im not sure if it is the pump car was running fine parked over night and now it has no fuel at spark plugs i have already check fuze it was good for pump any thing else i might try
Apr 29, 2019 at 5:41 PM (Merged)
IMPALASS
  • 3,112 POSTS
Hello –
To better assist you is your model the DX, EX or LX and please tell me your engine size in liter?
TUNIT69
this is not my car but pretty sure it is an lx with a 4 cylinder it is not a v-tec please include location how to get to it and book time thanx you very much
IMPALASS
  • 3,112 POSTS
Hello - It is much better if you know if the engine is a 2.3L, 2.4L or 3.0L as there may be something different with them and I don't want to mislead you. I do want to provide the best info I can...so if you can find out the size in liter that would be better. For now to make sure we are looking at the right thing, take some starting fluid and spray into the throttle body and see if it tries to start. Should take about 2 hours to change....book says about 1.3 Do you have any fuel pressure at all? Make sure you checked with an ohm meter, fuses 1, 11, 13 The fuel pump is located in the tank but you get to it through the trunk, there is a access panel in there.........(that is great and very lucky....many cars you have to drop the tank) As for the fuel pump replacement here are the direction for an LX...but I again, still would like to know the engine size in liter to make sure all my info to you applies to your model. FUEL PUMP REPLACEMENT 1. Remove the trunk floor. 2. Remove the access panel from the floor. 3. Turn the ignition switch OFF, then disconnect the fuel pump 5P connector. 4. Remove the fuel cap. 5. Relieve the fuel pressure (see Fuel Pressure Relieving ). 6. Disconnect the quick-connect fittings from the fuel pump. 7. Remove the bolts (A), and the fuel tank unit (B). Fig. 30: Removing Bolts & Fuel Tank Unit Courtesy of AMERICAN HONDA MOTOR CO., INC.
https://www.2carpros.com/forum/automotive_pictures/248015_30_1.jpg
8. Remove the bracket (A), the fuel filter (B), the fuel gauge sending unit (C), the hose (D), and the wire harness (E). Fig. 31: Removing Bracket Courtesy of AMERICAN HONDA MOTOR CO., INC.
https://www.2carpros.com/forum/automotive_pictures/248015_31_2.jpg
9. When connecting the fuel pump, make sure the connection is secure and the suction filter (H) is firmly connected to the fuel pump (I). 10. Install the parts in the reverse order of removal with a new base gasket, then check these items: "¢ When connecting the wire harness, make sure the connection is secure and the terminal (F) is firmly locked into the place. "¢ Check that the tab of the clamp (G) does not interfere with the wire harness. "¢ Do not push the lower part of the suction filter. "¢ When installing the fuel gauge sending unit, make sure the connection is secure and the connector is firmly locked into place. Be careful not to bend or twist it excessively. FUEL PRESSURE RELIEVING Before disconnecting fuel lines or hoses, release pressure from the system by loosening the fuel pulsation damper on top of the fuel rail. 1. Make sure you have the anti-theft code for the radio, then write down the frequencies for the radio's preset buttons. 2. Disconnect the negative cable from the battery. 3. Remove the fuel fill cap. 4. Use a wrench on the fuel pulsation damper (A) at the fuel rail. Fig. 11: Using Wrench On Fuel Pulsation Damper At Fuel Rail Courtesy of AMERICAN HONDA MOTOR CO., INC.
https://www.2carpros.com/forum/automotive_pictures/248015_11_7.jpg
5. Place a rag or shop towel (B) over the fuel pulsation damper. NOTE: Replace all washers whenever the fuel pulsation damper is loosened or removed. 6. Slowly loosen the fuel pulsation damper one complete turn. Here is a check you can do for the fuel pump. FUEL PUMP TEST If you suspect a problem with the fuel pump, check that the fuel pump actually runs; when it is ON, you will hear some noise if you listen to the fuel fill port with the fuel fill cap removed. The fuel pump should run for 2 seconds when the ignition switch is first turned on. If the fuel pump does not make noise, check as follows: 1. Remove the trunk floor 2. Remove the access panel from the floor. 3. Turn the ignition switch OFF, then disconnect the fuel pump 5P connector. 4. Connect the PGM-FI main relay 7P connector terminals No. 4 and No. 5 with a jumper wire. Fig. 14: Connecting PGM-FI Main Relay 7P Connector Terminals No. 4 & No. 5 With Jumper Wire Courtesy of AMERICAN HONDA MOTOR CO., INC.
https://www.2carpros.com/forum/automotive_pictures/248015_14_4.jpg
5. Turn the ignition switch ON (II). 6. Check that battery voltage is available between the fuel pump 5P connector terminal No. 5 and body ground when the ignition switch is turned ON (II). "¢ If battery voltage is available, check the fuel pump ground. If the ground is OK, replace the fuel pump (see Fuel Pump Replacement ). "¢ If there is no voltage, check the wire harness (see PGM-FI Main Relay Circuit Troubleshooting ). Fig. 15: Checking Battery Voltage Is Available Between Fuel Pump 5P Connector Terminal No. 5 & Body Ground Courtesy of AMERICAN HONDA MOTOR CO., INC.
https://www.2carpros.com/forum/automotive_pictures/248015_15_4.jpg
TUNIT69
It is a 2.3 liter and what is PGM-FI relay where would i find one would like to perform test before i change it and could you maybe go into more detail wit jumper wirer and test procedjure
MARKTHREE
This car was just fine when I parked it last night. Went out this morning and it turns fine but doesn't start, or even kick. I don't smell any fuel ( fuel gauge works and tank has at least 6 gal.) Fuel pump fuse appears fine, but I can't find the relay. Does the '98 even have one? Any other way to narrow down the problem? A way to troubleshoot the pump itself?
Thanks!
IMPALASS
  • 3,112 POSTS
Hello –
Please make sure you read the directions carefully to prevent any problems. The relay is on the car under the dash…..as it says you put a jumper wire from the 4 to the 5 plug on the wire side of the female terminals………..then check your fuel pump plug.
Hope this helps
Hi markthree, Welcome to 2carpros and TY for the donation.
Do you hear the fuel pump come On when you turn key to run if so check the fuel pressure.
Use a wrench to remove the fuel pulsation damper from its fitting.
https://www.2carpros.com/forum/automotive_pictures/12900_fuel_pump_32.jpg
8. Attach the fuel pressure gauge.
9. Disconnect the vacuum hose (A) from the fuel pressure regulator (B) and pinch it closed with a clamp (C).
10. Start the engine and let it idle.
o If the engine starts, go to step 12.
o If the engine does not starts, go to step 11.
11. Check to see if the fuel pump is running: remove the fuel fill cap and hold your ear to the fuel fill port while an assistant turns the ignition switch ON (II) you should hear the pump run for about two seconds when the ignition turned ON (II).
o If the fuel pump runs, go to step 12.
o If the fuel pump does not run, test it.
12. Read the pressure gauge (with the fuel pressure regulator vacuum hose disconnected and clamped). The pressure should be 320 - 370 kPa (3.3-3.8 kg/sq.cm, 47-54 psi) .
o If the pressure is OK and engine is running, go to step 13. If not running, repair the cause, then continue this test.
o If the pressure is out of spec, go to step 14.
13. With the engine running, unpinch and reconnect the vacuum hose and read the gauge again. The pressure should be 260 - 310 kPa (2.7-3.2 kg/sq.cm, 38-46 psi) .
o If the fuel pressure is OK, the test is complete.
14. Disconnect the vacuum hose from the pressure regulator again while you watch the pressure gauge. The pressure should rise when you disconnect the hose.
o If the pressure did not rise, replace the fuel pressure regulator.
o If the pressure is rose, but all your readings were lower than specified, check for a clogged fuel filter and for leaks in the fuel lines.
o If the pressure is rose, but all your readings were higher than specified, check for a pinched or clogged fuel return hose or line.
15. Reconnect the vacuum hose, remove the pressure gauge, and reinstall the fuel pulsation damper and a new washer. Tighten the fuel pulsation damper to 22 Nm (2.2 kg/sq.cm, 16 lb.ft) . NOTE: Disassemble and clean the fuel pressure gauge attachment thoroughly after use.
