1997 Honda Accord door panel removal
1997 HONDA ACCORD
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
TADOW12
I'm having trouble removing the door panel. I have taken out the two screws and popped the plastic buttons down the sides of the door and along the bottom, but I still can't free the door panel from the door. Can you please help me.
Nov 7, 2008 at 9:00 AM
IMPALASS
  • 3,112 POSTS
Hello The info you requested. In the future please ensure you provide the specifics on the engine size in Liters and the 8th digit of the VIN 1m Door Panel/Plastic Cover Replacement Remove the mirror mount cover panel NOTE : Take care not to scratch the door panel and other parts.
https://www.2carpros.com/forum/automotive_pictures/248015_1_20.gif
If applicable, remove the regulator handle by pulling the clip out with a wire hook.
https://www.2carpros.com/forum/automotive_pictures/248015_2_27.gif
NOTE: Install the regulator handle so it points forward and up at a 45 degree angle with the glass closed.
https://www.2carpros.com/forum/automotive_pictures/248015_3_20.gif
Pry out the cap and remove the screw.
https://www.2carpros.com/forum/automotive_pictures/248015_4_13.jpg
Pull the inner handle forward and out half-way, and disconnect the inner handle rod and power door lock connector.
https://www.2carpros.com/forum/automotive_pictures/248015_5_9.jpg
Remove the armrest screw.
https://www.2carpros.com/forum/automotive_pictures/248015_6_5.jpg
Release the clips that hold the door panel. Remove the door panel by pulling it upward. NOTE : Remove the door panel with as little bending as possible to avoid creasing or breaking it.
https://www.2carpros.com/forum/automotive_pictures/248015_7_6.jpg
Disconnect the following: Power window connectors Power mirror connector (driver's) Courtesy light connector
https://www.2carpros.com/forum/automotive_pictures/248015_8_4.jpg
Remove the bracket and power door lock control unit, and disconnect the connectors.
https://www.2carpros.com/forum/automotive_pictures/248015_9_3.jpg
Detach the grommets and harness clips, then carefully remove the plastic cover.
https://www.2carpros.com/forum/automotive_pictures/248015_10_3.jpg
Before installing the plastic cover, make sure the door harness and connectors are fastened correctly on the door.
https://www.2carpros.com/forum/automotive_pictures/248015_11_2.jpg
Install the plastic cover and all removed parts. NOTE ; Apply adhesive along the edge where necessary to maintain a continuous seal and prevent water leaks. Do not plug the elongated holes. Sedan; To prevent contamination, cover the hole at location A with adhesive tape. Install the door panel. NOTE: Make sure the door harness is not pinched. If necessary, replace any damaged clips. Make sure the connectors are connected properly. Install) the armrest pocket (sedan/wagon, passenger's) and inner handle. NOTE : Make sure the connector is connected properly. If applicable, install the regulator handle. See: Front Door Handle\Service and Repair Install the mirror mount cover panel.
Nov 8, 2008 at 1:04 AM
