1997 Honda Accord box with wires dangling above gas pedal
1997 HONDA ACCORD
140,000 MILES • 4 CYL • 2WD • AUTOMATIC
AM06TZ
Hello, i recently bought a 1997 honda accord, but i noticed that there is what seems to be a a wire box dangling over the gas pedal and I can feel it when I'm driving? the car drives smoothly though, what is the box? i suspect it is just missing a screw of some sort?
also my abs light stays on all the time, the dealer told me it is just a corroded wire, how much would that be to fix?
Oct 23, 2008 at 1:56 PM
KHLOW2008
  • 41,814 POSTS
Hi am06tz,
That could be the control unit of aftermarket alarm and is not properly secured.
As to the ABS light , you need to get a scan done to find out what is wrong. It might be an easy fix or requires a pump reploacement.
Oct 27, 2008 at 10:37 AM
AM06TZ
and another thing, I noticed that there is a blue cord coming from under my glove compartment it looks like and ethernet cord? what is that?
Oct 31, 2008 at 10:26 AM
KHLOW2008
  • 41,814 POSTS
Hi am06tz,
What does the cord look like? If it is 2 or 3 pin, then it could be for the Service Check Connector or Data Link Connector
Nov 1, 2008 at 10:37 AM
AM06TZ
https://www.2carpros.com/forum/automotive_pictures/260432_cord_1.jpg
hey this is not my car but, this is exactly what it looks like (the blue cord) I hope you don't mind my Q's i just want to know beforehand sometimes when I start my car, there is a slight rumble...nothing outstanding but...I heard this could be a cylinder "misfire" or i could just need new spark plugs??
Nov 1, 2008 at 11:59 AM
KHLOW2008
  • 41,814 POSTS
Hi am06tz,
No problem, anybody can ask any questions and we at 2carpros will try to answer as best as we can.
Looks like the Service Check connector but for 97 models it should be OBD II equipped.
Some connectors are not used as they are for some other accessories which this vehicle is not equipped with.
If there is any misfiring, you would most likely feel some vibrations.
It is not easy to understand and advise on noise problems.
Nov 1, 2008 at 1:08 PM
