my wipers work, but when i try to get fluid nothing comes out. i don't know where the washer pump is located or what else it could be?
Dec 4, 2008 at 12:02 AM
MHPAUTOS
CERTIFIED EXPERT
Hi there,
The pump is located in the bottom of the washer bottle, if you can hear the pump running, check that the nozzles are not blocked, use a pin to clear them, if you can't hear the pump it may of failed.heck power to the pump and if ok replace the pump.
