1996 Honda Accord Wet Floor Mats
1996 HONDA ACCORD
100,000 MILES • 4 CYL • 2WD • MANUAL
ABAYLIS
Hi. I would appricate your help in trying to locate the source that is causing the driver's floor mat to be wet. I have checked that the floor under the mat doesn't have holes, so I suspect the water is leaking in aroung the windshield when it rains. Do you have any other suggesting as to the probable cause?
Thanks in advance for your help.
Dec 13, 2008 at 10:12 AM
BULLHORN7
  • 28 POSTS
I had the same problem most likely the weather striping is worn or just not there any more. Weather stripping is cheap shouldnt be a problem to fix.
Dec 15, 2008 at 4:16 PM
