1996 Honda Accord Transmission drag and leaks
1996 HONDA ACCORD
99,000 MILES • 4 CYL • FWD • AUTOMATIC
NELLYB123
  • 6 POSTS
My Honda was 1/2 qt low on transmission fluid and since have found no leaks and doesn't check low; does a transmission use fluid regularly?
Also, I fell my transmission drags into gear a bit and when checking found a recall on the throttle for my model. Could throttle recall be problem for drag?
Tnx,
Jun 10, 2009 at 4:45 PM
KHLOW2008
  • 41,814 POSTS
Hi nellyb123,
Your model should be equipped with a throttle pressure cable and if all the gears are late in up shifting, most probably the cable is adjusted too short.
If the shifting is erratic and sometimes seems good, the throttle position sensor can cause it to shift erratically.
Another possible cause would be the speed sensor. thsi would happen if the speedometer is not functioning or functioning incorrectly.
Do you have the Check Engine Light showing or D4 light blinking while driving?
Jun 14, 2009 at 11:23 AM
NELLYB123
  • 6 POSTS
Yes, my 'check engine' light has been red. Thanks so much; I'll have the dealer check out the throttle cable as I think there was a recall on this.
Jun 14, 2009 at 7:40 PM
KHLOW2008
  • 41,814 POSTS
Get the trouble code for the Check Engine Light and let me know the exact trouble code.
Jun 15, 2009 at 9:39 AM
NELLYB123
  • 6 POSTS
Can you tell me how to get the 'Check Engine' light trouble code? Not even my brothers have heard of this! Tnx, Sharon
Jun 15, 2009 at 11:23 AM
KHLOW2008
  • 41,814 POSTS
Yours being a 96 model should be OBD II and code retrieval can be done with a scanner.
Most parts stores provides the service either free or for a nominal fee. Get them to check it for you and let me know the exact trouble code.
Jun 16, 2009 at 10:46 AM
NELLYB123
  • 6 POSTS
Thanks so much for all the info and being so helpful; this was probably in my manual and so excuse me for being so ignorant. I will have the code checked out and get back with you.
Jun 16, 2009 at 11:58 AM
KHLOW2008
  • 41,814 POSTS
I seldom come across people who knows what are in the manual so you do not need to feel bad about it.
Let me know what you find and we can try to figure it out for you.
Jun 17, 2009 at 6:51 AM
NELLYB123
  • 6 POSTS
Asked my brother and he said its not my engine light thats on, its the red maintenance light. So now Im back to just my transmission problem. It was 1/2 qt low about three weeks ago after not checking for I don't know how many years (terrible). Now since adding and checking every day for three weeks the transmission fluid level has remained okay. Still feel though the shifting is sluggish and wonder about the trottle recall. Do you suggest that I just have my Honda dealer check out? Im at 99,000 mi and want to keep and get 100 T more miles so will start really taking care of her. Tnx so much, Sharon
Jun 18, 2009 at 12:06 PM
KHLOW2008
  • 41,814 POSTS
Hi Sharon, The maintenance service reminder can be reset to green by inserting the ignition key into the slot as shown in diagram.
https://www.2carpros.com/forum/automotive_pictures/192750_SESreset96Accord_1.jpg
If you feel the trans is not shifting correctly, it would be advisable to get it checked. Call the honda dealership and check if you can get the throttle replaced under the recall.
Jun 18, 2009 at 12:32 PM
NELLYB123
  • 6 POSTS
Wonderful info; tnx so much and great clear diagram. Will set up appt with dealer. Sharon
Jun 18, 2009 at 2:06 PM
