1996 Honda Accord Lights behind heat and a/c controls are n
1996 HONDA ACCORD
20,200 MILES • 4 CYL • 2WD • AUTOMATIC
DANNYCRAWFORD
The lights behind the heat and a/c controls do not work. When driving at night you can't see the controls to adjust the settings. Are the bulbs themselves possibly burned out? The lights for the instrument cluster are fine. I didn't know if these are on the same fuse or if there is possibly a separate fuse for the lights behind the heat and air controls. If I do have to replace the bulbs, do I have to remove the center console in order to get to the screws that loosen the housing for the heat and a/c control unit? I have a Haynes repair manual and just from what I can deduce from that , I will need to remove the radio and possibly the center console in order to get the heat/ac module out to change the lights. If I do have to replace those bulbs, I just need to know if this is what I need to do or is there is an easier/guicker way to get to them. Thanks in advance for any help that you can offer.
Jan 23, 2010 at 6:40 PM
2CARPRO JACK
  • 11,533 POSTS
No, there isnt a seperate fuse for just thos elights.You have it right unfortunatly, you have to remove the bezel around the climate control to access the unit for removal to replace bulbs that are located in the rear.
Jan 24, 2010 at 10:21 AM
