1995 Honda Accord transmission trouble
1995 HONDA ACCORD
193,000 MILES • 4 CYL • FWD • MANUAL
MADDMAXX5858
my son said he was on the way home. he puts car into first gear hears some sort of grinding on right side (sounded like it was under the car floorboard) . will not move after that. is it the slave clutch. or something else trashed. i jacked the car up. can grab passenger side cv axle and turn it. it will make some sort of clunking noise, like something is broken loose . what is your verdict?[img:1811bc7ddf]http://www.2carpros.com/forum/automotive_pictures/543643_guitar_1.jpg[/img:1811bc7ddf]
Jun 26, 2010 at 1:11 PM
TED-E-DEE
  • 109 POSTS
That is very unusual. Did u verifie oil level & ck. underneath of trans. case for poss. hole from road debris ? If oil o.k. , sounds like differential broken providing all o.k. out at wheels. But 1st ck. the following---- If u hear noise inside trans. when spin axles, be carefull noise travels ! Be worth your while to r & r both axles remove boot bads & look inside, inner or outer joints on axle shafts may also be broken inside. QUICKEST CK.-- With flat edge pry bar pop inner axle joint - " PATIALLY " - out of trans. w/drain bucket under trans.. Then remove kotter pin & 17mm nut lower ball joint. Pop ball joint from lower steer knuckle. CAREFULLY pull inner joint out of trans. w/ a squeeze method holding joints together as u pull . This will prevent joints from seperating inside which can be difficult to fix w/out take appart. Usually if pulled out by inner joint this wont happen. GOOD LUCK !
Jul 1, 2010 at 12:54 AM
