1995 Honda Accord ticks and smokes.
1995 HONDA ACCORD
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
YIGYYO
  • 4 POSTS
Hi, I've recently purchased my Accord and realized after the purchase that on a cold start, after about 30 seconds the engine will start ticking loudly. It will last for 2 to 3 minutes until the engine warms up. When the ticking starts it will be loud and the sound will become les audible by the last half of the 3rd minute or so, then it will stop completely. After the sound is gone is about the time the smoke starts coming out the back. (when the engine is warm) It is not thick, not black or white, but a greyish color. it will thicken a bit as the engine warms up, but not real bad. some details about the car that may help, or may not help at all are: timing chain was claimed to have been changed at some point, coolant is toped and fresh green in color, oil is topped, a few months old, but clean, not milky. the oil levels may drop, but I just purchased the car last week and its been parked(have not had the chance to drive it around much.) There is some old oil around a valve cover. The sounds is coming from the top center of the engine, not over either of the valve covers. but right in the top middle of the car. It is pretty loud, can hear it from inside the car, and loud enough when you drop your ear to the engine can tell its coming from the center. Its a 2.7L V6. Any insight would be greatly appreciated. I heard it could be my lifters, could even be an oil clog. I have no clue.
Anyway, thank you!
Jun 17, 2008 at 11:46 PM
AIRSOFTSOLDRECN9
  • 348 POSTS
The ticking noise is probably comming from you valvetrain which would require you to remove your valve cover. Possibly a sticky valve due to high carbon deposits although oil seepage can do this too. Grey smoke would indicate the car running too rich; however a compression check on the cylinders will make it clear whether you have a mechanical problem or not.
Jun 18, 2008 at 12:16 AM
YIGYYO
  • 4 POSTS
If the smoke was caused by burning rich, wouldn't the smoke be immediate instead of after warm up? If not, bare with me :) and by burning rich, do you mean the gas to air ratio is off?
Jun 18, 2008 at 1:36 AM
AIRSOFTSOLDRECN9
  • 348 POSTS
Your mixture could be below stoichiometric efficiency, not a proper burn in the combustion chamber or your timing is slightly off. First check your spark plugs if they are fouled and correctly gapped. If nothing turns up then test the oxygen sensor. Finally check the timing as it may be off. Even a 5 degree difference between the timing mark alignment on your timing belt will cause problems. A computer tester either OBD I or II should help.
Jun 18, 2008 at 12:04 PM
KHLOW2008
  • 41,814 POSTS
Hi YigyYo,
This engine utilises hydraulic lifters, so possibily one of it is not so efficient.
As to the smoke, if it is a little bluish and increases with revving the engine and suddenly disappears, to come back shortly, most probably the engine is burning some oil. The valve seals should be due for replacement.
Jun 18, 2008 at 12:38 PM
