1995 Honda Accord radiator fan turns on randomly and kills
1995 HONDA ACCORD
DOMINIC11
Engine Cooling problem
1995 Honda Accord 4 cyl Front Wheel Drive Automatic
i have a 95 accord ex and for about the past 6 months the radiator fan to the left turns on at night or when the weather is cool. this kills my battery. me and my step dad have checked all 3 sensors the run to the fan and all of them work. the fuse that runs part of the cooling system works, and i have take this fuse out everyday when im home so the fan doesnt turn on. the only thing that we could come to believe is that there is a short in the wiring. we think this cuz the fan only turns on when its cool outside. my hayes honda accord book doesnt have this part of the wiring system. SOMEONE PLEASE HELP ME!
Jul 29, 2008 at 12:16 AM
Here's your cooling fans EWD you should be able to knock this out. Have you checked/tested the coolant temperature sensor and the fan relay.
https://www.2carpros.com/forum/automotive_pictures/12900_fan1_1.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_fan2_1.jpg
Jul 29, 2008 at 4:09 AM
DOMINIC11
yes we have checked all 3 sensors and the relay switch. they all work. this is why we think its the wiring... we think wen it gets cool outside the wiring is shrinking and theres a short somewhere
Jul 29, 2008 at 10:42 AM
If the wire is not shorted or open investigate the computer
Jul 29, 2008 at 4:20 PM
DOMINIC11
so do you think there is a short? what do you think is wrong? my hayes book for honda accords doesnt show this part of the wiring system.
Jul 29, 2008 at 11:42 PM
The computer is the one that activates the relay
Jul 30, 2008 at 11:59 AM
J DAVIS
Was the problem with the fan coming on by itself, ever fixed, if so what solve the problem?
Jan 31, 2010 at 5:21 PM
KAWGOMOO
The problem with this car is the fan timer. Basically a little black box up under the dash right next to the main relay.
it has a small black plug, at least one wire should be yellow/black.
Just replace that little box. Its clearly labeled fan timer control once u finally get it out.
Oct 5, 2010 at 11:03 PM
